It is currently Mon Aug 04, 2025 10:58 am
PostPosted: Mon Feb 16, 2009 10:16 am
Any thoughts on these tools? The table and 17" band saw are $799 and the scope is $299.
http://www.harborfreightusa.com/usa/ite ... emid=93380
http://www.harborfreightusa.com/usa/ite ... temid=3179
http://www.harborfreightusa.com/usa/ite ... emid=95833
PostPosted: Mon Feb 16, 2009 10:25 am
Being on a strict budget, I'd be interested in the bandsaw but would want to inspect it carefully first. Maybe show up at the store with some measuring tools to check wheels, guides, and so on. Looks a lot like the Grizzly 17" that is on sale for $770, and might come from the same factory.
Like most folks, I've had good and bad luck with HF tools. You just never know for sure what you're gonna get. But Grizzly has been fairly consistant for me; Not the best but workable with a little tweaking.
PostPosted: Mon Feb 16, 2009 10:34 am
Yeah I have to agree with you that they probably come from the same factory. Just like the mini mills. The problem with checking them out is they are special order items. I think the scope is a pretty neat item for interior inspection and it's color with a AV out put and 3 LED lights.
PostPosted: Mon Feb 16, 2009 10:41 am
Personally, I'd be skeptical. Most everything I've ever seen at HF was crap. I would never purchase the subject equipment you have listed without personally inspecting it first. Spending a few hundred $$ more on quality equipment would be my recommendation.
Hi Chris, I think the table is small for a 17" bandsaw.And 2HP motor is too small also.I'd rather have our 14" rikons.
PostPosted: Mon Feb 16, 2009 12:38 pm
First name: Darrin
Last Name: Oilar
City: Cottonwood
Zip/Postal Code: 96022
I find some cool values at HF. I was able to turn their sheet metal nibbler into a fret tang nipper. I epoxied a fret crown file insert to their goose neckd screwdriver. Their deep throat clamps are pretty good value and good as a bridge clamp, with a 1 in 10 chance that the business end of it will actually align with one another.
But outside of maybe their drill press, I don't know that I would buy any equipment from them.
I'm sure that a lot of their stuff rolls down the same lines as the other manufacturers whose equipment we often hold in higher regard. But I think the difference is in quality control and what each one perceives as allowable tolerances.
I would therefore say a resounding no to the equipment purchases. I think a little webcam mounted on some brass rod with an LED headlamp and then spending the remaining $249 on zoot would be a better way to go. :) Of course I'm frugal and my middle name is Jerry Rig.
Darrin
PostPosted: Mon Feb 16, 2009 1:02 pm
Todd Stock wrote:
On the 'same plant' stuff...saying that a power tool comes off the same line ignores the fact that the differences which make a band saw either a joy to use or a constant PITA are all in areas which resist casual inspection (bearings, guides, drive train (including motor), finish (i.e., balancing of wheels, sheaves), and QC). All of these things are specified by the ordering customer, so radically different products can come from the same line.
Absolutely
Users browsing this forum: JimWomack and 29 guests
